Hi all, Does someone know how to make an offset from the points after using command “divide curve”. The offset should follow the curvature.
3. Attach minimal versions of all the relevant files
I think you can use the Perp Frame command to create planes at each of the points on the curve. Then move the points in these planes on the axis that you want the offset.
