"offset Curve on Surface" Rhino 7 crash
i have a new machine at work and since then, when i use the command “Offset Curve on surface” it freezes and when i press cancel an instability Alert shows up (Rhino unsafely canceled the command you were running…)
IT installed various Rhino 7 versions and always the same crash happens.
Is it a hardware problem?
Run the Rhino command SystemInfo and post the results here.
Torsten is currently using Rhino 7.16 which has been cleanly removed and re-installed today.
He accesses his desktop remotely from home via RDP remote desktop connection - could this be the reason?
We will add the systeminfo asap.
Hi Richard -
Yes, RDP is not supported - Rhino - System Requirements
I doubt it comes from the Tomate desktop as it worked fine before.
Anyway, here the systeminfo:
Rhino 7 SR16 2022-3-8 (Rhino 7, 7.16.22067.13001, Git hash:master @ aa7902c94c5aa33511e60d30f82b636be43bc85f)
License type: Commercial, build 2022-03-08
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP (Hosting Remote Desktop session)
Primary display: Microsoft Remote Display Adapter (Microsoft) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
Remote Desktop display device with 16 connection(s)
  • Windows Main Display using connection #0
Primary OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 1-28-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.65
Accelerated graphics device with 0 adapter port(s)
  • There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-28-2022
Driver Version: 30.0.15.1165
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.16.22067.13001
Just a guess. Try disabling V-Ray and restarting Rhino. V-Ray caused a seemingly unconnected problem a while back.
Disabling Vray was the solution.
Thank you,
Topic closed
