I have IncrementalSave set for 120 secs. in the IdleProcessor. This works fine most of the time but every so often it will go crazy. Yesterday I had 73(!) copies of my drawing saved in less than 10 minutes. I had this happen once before and more than 99 copies were created in a brief span of time. I can’t trace this to anything different that I’m doing. Any thoughts?
Hello - I have never heard of this - do you see InrementalSaves crowded up in the command history when this happens? Presumably so… but just checking
Hello - - another shot in the dark but if Enter repeats the last command, (I have not tested this with IdleProcessor) it could be that a few perfectly timed Enters or space bars, or RMB is firing off the command again. If that is the case, you’ll want to put IncrementalSave in the Do not repeat commands in Options > General page.
