I am working on a rather large file that started as a import of a Sketch-up based massing model. It is an area of Downtown Saint Paul, Minnesota. Initially the file was sluggish to non-responsive due the massive number of polygons it held, however, after extensive merge face commands, the base imported geometry begin to becomes noticeable quicker when rotating the view or navigating the model. Recently, something odd happened, the perspective viewport stopped displaying the entire model geometry at all. If i put the view into parallel it worked fine, and top, bottom, right and left all remained unaffected. I was able to get the geometry to reappear finally put now while i am rotating the view it suddenly disappears and will re-appear at random. I am new to this forum and a relatively new Rhino user so any help in this would be greatly appreciated. I am using a Mac beta version of Rhino 5 with today’s update installed currently, however this issue first occurred while running the file on my desk top PC at work which is running Rhino 5 with a grasshopper plug-in installed but not in use in this specific file. I have attached a screen shot of the described problem.
Below is a copy of my settings info for your reference.
Software information
Software versions
Rhinoceros version: 5.0 Wenatchee 2014-08-27 (523)
OS X version: Version 10.9.4 (Build 13E28)
Plug-ins
None
Third party kernel extensions
None
Hardware information
Computer hardware
Hardware model: MacBookPro8,3
Processor: Intel Core i7-2720QM CPU @ 2.20GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: AMD Radeon HD 6750M 1024 MB
Memory: 1024 MB
Screen size: 1920 x 1200
Displays: Color LCD
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Kingston: DataTraveler 2.0
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: Apple Internal Keyboard / Trackpad
Microsoft: Microsoft® Nano Transceiver v2.0
Apple Computer, Inc.: IR Receiver
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 ATI-1.24.35
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: Yes
Appearance settings
Antialiasing: 0x
Mip map filtering: None
Anisotropic filtering: None
Thanks,
David Horner
