as you can see, the whole model disappears when I rotate the camera, and it’s only visible from the top standard view (i have tried the others, that did not help). It just started acting like this randomly in the middle of a session! Does anyone know what might be wrong with it?
nevermind, I found a solution!
for anyone encountering this issue, I fixed it by creating a new viewport ![]()
Hi Vlad, which orientation did you create? Just curious—-Mark
Hello. I think you have a problem with the focal length. Try using the _Zoom and _ZoomLens functions.
I used the NewViewport command, it seems like the default is set to Top.
Select object>Zoom Selected>Rotate View
Hello, I have the same problem as you have in the video. But the new viewport did not fix my problem. And it’s always, even if I make a new file. I am using Rhino 8.
Hi Daniel -
Please run the Rhino SystemInfo command and copy-paste its output here.
Rhino 8 SR23 2025-9-8 (Rhino 8, 8.23.25251.13001, Git hash:master @ e75a9d62e23cc6f52d4ef68eb7eda9f8da9b6cd9)
License type: Educational Lab License, build 2025-09-08
License details: Cloud Zoo
Expires on: 2025-11-01
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.14
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 9-5-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.29
Integrated accelerated graphics device with 4 adapter port(s)
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 9-5-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.29
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-13-2022 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-5-2025
Driver Version: 32.0.15.8129
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\Daniel\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 8\D5Conv.rhp “D5 Sync for Rhino”
C:\Program Files\pollination\plugin\8.0\Pollination\Environmental_Analysis.rhp “Environmental Analysis” 0.0.0.0
C:\Program Files\pollination\plugin\7.0\Pollination\Pollination.RH.rhp “Pollination.RH” 1.46.0.0
C:\Users\Daniel\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Lumion-LiveSync-for-Rhino\3.60.65\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.175\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.175.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.46.0\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.46.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.23.25251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.23.25251.13001
I’d be curious is disabling d5 live sync and lumion live sync help at all-
Also I’d be curious to see if this happens if you remove your 2nd monitor as a test temporarily.
I had the same problem and solved it by using the SetView command.
SetView>World>Perspective
