Object snapping not working
Object snapping is not working, even when I set Modelling Aids to the default setting and check that it is not snapping only to selected objects or the C plane.
hey Catherine, we’ll need a little more to go on here-
mac or pc?
can you send a screen shot of your osnap filter settings?
post a model that is misbehaving?
screen recording showing the issue?
Hi Kyle,
Thanks for your help.
I am using a PC. I’ve attached a screenshot of my osnap filter settings, a recording of the problem and the file itself.
Many thanks,
Catherine
(attachments)
Main Building.3dm (240 KB)
these are my osnap settings and my filter settings.
I’m betting you have one of these set wrong which would cause this issue-
fwiw, I run all my osnaps on, but disable the entire pallet, then use ALT to temporarily enable them when needed so that I don’t have to constantly check and uncheck things.
I also very much dislike having osnaps popping off all the time when I’m navigating a model like some caffeinated toddler looking for attention while i’m on a phone call.
