Hi, I have a display issue - this completely disappears in Arctic view, with surface edges off. I am out of ideas of how to solve it - i’ve created new files, i moved everything in one folder with white material, i’ve checked settings, tried flipping the surfaces. Does anyone know what the solution is, please?
SystemInfo might be relevant as well. Please run the command in Rhino and post the results. Thanks!
Hi Oana -
It’s close to impossible to troubleshoot an image. Please post the .3dm file or export a small part of it to a new .3dm file and make sure that that part still shows the behavior.
Also, as Japhy already requested, please run the Rhino SystemInfo command and copy-paste its output here.
try SetObjectDisplayMode on that object and enter, you dont have to select anything in specific in that command, the default setting will set it to normal.
thank you, I tried it, it’s not solving the issue, unfortunately
Hi Wim,
Please see below:
Rhino 8 SR21 2025-7-7 (Rhino 8, 8.21.25188.17001, Git hash:master @ 2e05bb7e11ec03aa58cc543d92330d59df05d32b)
License type: Commercial, build 2025-07-07
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.21
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P4000 (NVidia) Memory: 8GB, Driver date: 8-7-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 580.97
Accelerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-7-2025
Driver Version: 32.0.15.8097
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.21.25188.17001
C:\Users\oa\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.21.25188.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.21.25188.17001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.21.25188.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.21.25188.17001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.21.25188.17001
it would save us a lot of guessing if you would post your stripped down file, just duplicate the file and eliminate everything that is not relevant and post only that geometry.
what you still could try is MatchProperties, select one of any of the other objects and match the properties from this geometry to the others.
This ![]()
If it’s an imported mesh object, you could try RebuildMesh on it, to see if it helps. Also make sure it’s not a block.
HTH, Jakob
