Object Casting Shadow Through Solid Object
VRay%20Issue_Two%20Shadow_Render
Hi All,
I’m currently trying to just do quick shadow studies, and I’m simply using a Rhino sun set at a given time, set material for all context objects to not cast a shadow with the exception of the object in study. However, for some reason the object is casting two shadows - one which is the correct shadow against a neighbouring solid, but the another one that seems to go straight through it… Does anyone know what might be causing this?
Cheers,
Xin
Looks like you would need to set your environment objects to not receive shadows too. I’m not sure there is an option like this.
