I recently changed from Rhino 6 to Rhino 7 and I noticed one small issue when drawing a simple line.
In Rhino 6 and older versions when I wanted to draw a simple line I would point to the starting point, then key in the distance ( example 1 for one inch ) and then move the pointer in the direction I wanted to draw the line and then just click the mouse button at any point in that direction and it would create the 1 inch line.
When I try this in version 7 it extends the line out to where ever my mouse pointer is located, and disregards the distance I keyed in.
Is this a known issue, or is an option that I need to change
Thank You,
Kent
