Hi All,
Is anyone else experiencing this.
It’s only just happened with the latest Rhino 7 update.
Normally when you do Offset Curve. You select the curve. Type in the number you want to offset (eg:15)
Move the mouse for the side to offset. Then click left mouse button once.
What’s started happening is:
Move the mouse for the side to offset. Then click left mouse button once. It doesn’t offset the number you typed in, but offsets the number in the ‘Distance=’ parameter.
Now in order to offset the number I want. I have to press Return before I click the left mouse button.
I use this function all day long so the extra Return press is annoying.
How can I change it to work like before?
Thanks.
