The window keeps showing the loading screen, even though I can already toggle on/off windows from the menu dropdown. I had it loading more than an hour, it will not finish.
Attached also a strange situation with the loading window still there in the window, but at the same time the working window where I could actually click on things and change settings.
Hi - does this happen for one particular file or generally for all files?
Please run the SystemInfo
command and post the results here. If you have a 3dm file that reproduces that issue on your end, please also post that.
It’s only that file. I tried Audit, Audit3dmfile, opening on another computer. Just exporting it to a Rhino 5 file, opening it there and then opening it again with Rhino 6 worked.
I uploaded the file through your form already if you want to check that.
Rhino 6 SR19 2019-10-22 (Public Build, 6.19.19295.01282, Git hash:master @ 0af62045bd35259d4c2367dbf7f9ef94ded29299)
License type: Educational, build 2019-10-22
License details: Cloud Zoo. In use by: Nils Köpfer ()
Apple Intel 64-bit macOS Version 10.13.6 (Build 17G8037) (Physical RAM: 40Gb)
Mac Model Identifier: iMac18,3
Machine name: AtelierKanal_5
Language: en-BE (MacOS default)
AMD Radeon Pro 580 OpenGL Engine (OpenGL ver:4.1 ATI-1.68.23)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Graphics: Radeon Pro 580
Displays: iMac (217dpi 2x)
Graphics processors
Radeon Pro 580 (8192 MB)
iMac (2560 x 1440)
USB devices
Broadcom Corp.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
Logitech: USB Optical Mouse
Bluetooth devices
Broadcom: Magic Keyboard with Numeric Keypad
Third party kernel extensions
org.pqrs.driver.Karabiner.VirtualHIDDevice.v061000 (6.10.0) 4D004D1A-ED2F-3780-AD53-A10F286EC759
Third party plugins
/Library/Frameworks/iTunesLibrary.framework/iTunesLibrary
Rhino plugins
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.19.19295.1282
/Applications/Rhinoceros.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.19.19295.1002
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 6.19.19295.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.19.19295.1282
/Applications/Rhinoceros.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.19.19295.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.19.19295.1282
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.19.19295.1282
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 6.19.19295.1282
/Applications/Rhinoceros.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.19.19295.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.19.19295.1282
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.19.19295.1002
/Applications/Rhinoceros.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 6.19.19295.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.19.19295.1002
Hi - thanks for that file! There was an issue (RH-55580) with dealing with multiple viewports correctly.
This has been fixed for the upcoming 6.21 (for which a Release Candidate is now available) and 7.0 WIP versions.
[Fun fact - I have a brother who works right across the canal from that building ;]
Is this bug persistent in 6.20.19323.01022?
I just updated from 6.19 to 6.20.19323.01022 and performance is impressively slow. I face the the same behavior @atelierkanal is describing, with the difference that if I wait long enough the file finally opens.
However, even creating a blank new document takes a minute.
what is your estimate V 6.21 is released? Currently I cannot use Rhino on Mac …
Hi - this sounds like something completely different.
Can you please post a file that is giving you problems?
Also, are you saying that performance of 6.20 is worse than 6.19?
Please run the Rhino SystemInfo
command and post the result here.
