Hello, we have a problem with normalMaps.
In v3 it acts differently from v2, before it gave relief and now it is flat.
I attach 2 images where you can see with normalMap and without normalMap.
It is possible that the default amplitude for normal maps is different in version 2 and 3 of the viewer. Could you please point me to a ShapeDiver model online so I can compare the results in both viewers?
hello, is there news on this topic?
Hello @Jose_Antonio_Ordoñez
I just had a look at the model on both, the old (viewer 2) and the new (viewer 3) platform.
The issue is relatively simple, this is just due to the settings chosen for the model. As the settings are not supported in Viewer 2 / the old platform, the model looks different in general. This also has an effect on the normal map. The normal map is there in Viewer 3, it is just not nearly as pronounced due to the settings chosen.
Hope that helps.
Cheers, Michael
