jasiu.mk
(Jasiu Mk)
1
there used to be preview of texture possible to check in display menu in rhino 7
rhnio 8 removed this option and there is no non rendered view with texture preview
i used it every day in rhino 7 and now i have to use rendered view which takes forever to see if texture is correct
im losing my mind
wim
(Wim Dekeyser)
2
Hi Jasiu -
I’m not seeing that here with the current versions of Rhino 7.
Here are those panels side-by-side from Rhino 7 (left) and Rhino 8 (right):
As far as I can see, only the “Transparency” setting is no longer there.
In both versions, you set the material viewing options in the display mode settings:
