Hi All.
Having issues with textures showing in rendered view in rhino7.
Its fine with 6. I just dont know what ive missed.
Thanks for your help
Cheers
Brad
Hi Brad - can you post that file or send to tech@mcneel.com with a link back here in your comments? And can you please also run the SystemInfo command in Rhino and copy/paste the results here.
Hello - thanks - you did not include a mirror material, but if I make one it all looks correct here .
V6:
I see that your V7 is behind by a service release, so you may want to check for updates (Help menu) and I also see that you have Enscape - is that getting into the act as well? You can disable that in Options >PlugIns page (then close and restart Rhino) and see.
