I can’t seem to get any shadows to cast on the ground plane or on the ground surface of the object.
I have switched on the shadows in the document properties > view > display mode > render > shadow
I have also turned on the sun and set it to daytime in my location
Shadows in the display settings is turned on.
It used to work in one of my models and then the next day when I opened it, it no longer cast the shadows. The light is projected onto the vertical surfaces, however not on the ground plane. I tried re-installing rhino but this still doesn’t work in my old file and also when I create a new one.
Do you have any idea what could be causing this?
I had a friend look at it for me (who is quite good with rhino) and he also could not figure this out.
