There is no “rhino script” in options RH6, where did it go and how to put it back there?
Thnx for the prompt answer , i tried the repair, it said successful but nothing changed.
Hello - the next thing to try is to set your ‘Update frequency’ to ‘Service release candidate’ in Options > Updates and Statistics. Then click on Check Now - that should get you to the 6.30 service release candidate that as a fix in it that should help…
Any luck?
did not work either
Hum. Let’s do the obvious thing that I should have had you try initially - open Options >Plug-ins page and look for RhinoScript - is that there, and enabled?
bingo!
thnx Pascal for your unflinching resolve.
i wish u the best.
