No bumpmap at all
This is maybe a topic for @nathanletwory
Today I try to render a scene with a bump map. I am not able to create a (cycles) rendering with a bump map.
I also try to set the bump.strengh.factor to 10
I use a pbr material. To test the bump there is just a bump and a light grey in the Material.
In the rendered Viewport (not Raytraced I am able to see the Bump map)
In the Retrace mode oder while rendering the bump map is gone. I also try bella to find out where the problem is and bella is able to render the bump map with the same material settings.
no Bump with Cycles:
Bump with Bella:
Bump in rendered viewport:
my System info:
Rhino 8 SR21 2025-6-10 (Rhino 8, 8.21.25161.18002, Git hash:master @ d1727ccd678f61173f568509b05829e0850184bf)
License type: Commercial, build 2025-06-10
License details: Cloud Zoo
Apple macOS Version 15.5 (Build 24F74) (Physical RAM: 64GB)
Mac Model Identifier: Mac16,5
Language: en
.NET 8.0.14
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M4 Max
P27u-20 (2560 x 1440 @ 60.00Hz)
GPU Vendor: Apple
USB devices
Realtek: USB 10/100/1000 LAN
Apple Inc.: Apple Keyboard
Lenovo: P27u-20
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/thingybook/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/bella_rhino.rhp/libbella_dotnet_native.dylib
/Users/thingybook/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/bella_rhino.rhp/libdl_usd_ms.dylib
/Users/thingybook/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/bella_rhino.rhp “Bella” 25.3.0.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.21.25161.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.21.25161.18002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.21.25161.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.21.25161.18002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.21.25161.18002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.21.25161.18002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.21.25161.18002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.21.25161.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.21.25161.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.21.25161.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.21.25161.18002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.21.25161.18002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.21.25161.18002
Your BumpStrengthFactor may need to be as high as 1000 to make it work…
try setting the bump strength factor to like 1000
this is a bug we are trying to sort.
