I try to make cross joints and screw holes on a reciprocal timber structure using the Ngon plugin.
I made the joints and got the final result in mesh form. But I can not get the Brep result with the screw holes(using the Tile_NN_Screw component).
It seems like I have got the right Elements and Cutters, but when I feed it into BrepBooleanDiff, the result is not there.
I try to follow the Ngon example files to solve this problem for almost 4 hours, but couldn’t. Please help! And If you know any tutorial or article on how to use Ngon to make joints, please share, Thank you!
HI @Quan_Li, I opened your script but faced an issue with the BrepBooleanDiff Component. Do you know why this is so? I am opening the file in R8. Or perhaps @Petras_Vestartas, you could advice on this.
