Problem with Ngon joints
Hello! I have an issue with the joint function in Ngon plugin in grasshopper. I can not get the joints to work in my own file or even in example file that Petras Vestartas supplied in another topic [NGon 3.0.0 - Update for Wood-wood connections - Gallery - McNeel Forum] (NGon 3.0.0 - Update for Wood-wood connections - #3 by Petras_Vestartas). Somebody have a solution or a tutorial to the joint function?
Thank you
Jakob S.
CrossLapJoints.gh (19.8 KB)
Joint problem.gh (114.5 KB)
@Petras_Vestartas
Do you have planar geometry?
For cross try this:
CrossLapJoints.gh (17.9 KB)
And regarding the panels side connections, sides must be planar and touching to each other:
Side.gh (34.1 KB)
I am also rewriting this code to compas_wood package that is still :steam_locomotive: under development :steam_locomotive: (compas_wood - Table of Contents) :
