Rhino WIP 2017-Apr-26 is now available.
Download Now.
Enhancements:
New Features:
- Annotation: Styles: Force dimensions arrows inside, text outside and underlined (RH-21176)
- Grasshopper: Add Rhino6 only load folder for Grasshopper. (RH-38222)
Bugs Fixed:
Annotation:
Annotation: DimAngular: Dimensions incorrectly only consider model space geometry (RH-38517)
Annotation: Text:
Area: Report tune up needed (RH-38947)
ClippingPlane: Don’t work in technical modes (RH-38663)
CurveThroughPolyline: Closed curve start-end location in CurveThroughPolyline when CurveType=ControlPoint (RH-38978)
Cycles:
- Add a way to reset settings to defaults (RH-38981)
- Changing max sample count in HUD doesn’t change all the way to the engine (RH-38987)
- Hide viewport properties page when active view is not in Raytraced mode. (RH-38759)
- Shadow Only ground-plane is broken (RH-39037)
- Viewport lock not working properly (RH-38962)
DPI Aware:
Dir: Flip does not update display (RH-39007)
Display:
DivideAlongCreases: Area estimate incorrect (RH-38853)
EditScript: The default input language for RhinoScript Editor should be English (Narrow). (RH-26037)
Export: Export Selected doesn’t overwrite an existing file (RH-39004)
File IO:
FilletEdge: Edit option in Fillet/Chamfer/Blend Edge missing in Rhino 6 commercial build (RH-38982)
Help: Documentation on Annotation Style Panel -> Right Click Menu (RH-38717)
Layout: Layout window always appears (even when closed in previous session) when opening files that contain layouts (RH-36527)
PluginWizards: Create new RhinoCommon wizard for VS2015 and VS2017 (RH-39065)
RDK:
SDK: RhinoCommon:
- Review V6 SDK Cleanup Document (RH-38932)
Sweep1:
TweenSurfaces: Tween workflow (RH-38927)
Download Now and report any problems in this forum.strong text
