Rhino WIP 2017-July-27 is now available. Download Now.
New in this release:
Bug Fixes:
- Annotation:
- Alternate dimension text resolution scales over dimension size (RH-39638)
- Change zero suppression to skip 0 whole inches when there are 0 whole feet (RH-39574)
- Collapsed edit box in dimension properties (RH-39059)
- Dim command sometimes fails silently after using Continue or Baseline mode (RH-39569)
- Dimension object properties controls - vertical alignment problem (RH-39060)
- DimensionLengthDisplay returns wrong value (RH-40186)
- Editing multi-line dimension text (RH-39568)
- Feet and Inches and Inches fractional dimension display is broken. (RH-40253)
- Feet/Inch display fixes for dimensions (RH-39948)
- Limits tolerance skips main dimension (RH-39953)
- Linear Dimension Continue broken in 2nd model opened (RH-39960)
- Make alt units tolerance values scaled appropriately from length unit values (RH-39849)
- Multiline text through scripting (RH-1950)
- Rhino crashes in DimStyles in Options Dialog page (RH-40272)
- Saving a dimension from V6 to V5, the dim text is converted from <> to the text of the dimension (RH-39577)
- Use Alternate Units produces wrong value if Linear Units is overridden (RH-39781)
- Zero suppression error on dimensions (RH-40195)
- rounding issue (RH-39622)
- Annotation: DimLinear:
- Annotation: Styles:
- Annotation: Text:
- ApplyEdgeSoftening: Mesh too coarse, causes self-shadowing artifacts (RH-39563)
- BlockEdit: Double clicking on a block does not bring up BlockEdit (RH-39758)
- Camera: Interferes with view commands (RH-39617)
- ClippingPlane: Fills and intersection lines don’t work well with blocks (RH-39385)
- Cycles:
- ClippingPlane cannot be disabled in Raytraced mode (RH-40137)
- Incorrectly changes the environment (RH-38894)
- Produces white output when rendering Raytraced with modified output dimensions (RH-38977)
- Renderer should stop working when we ship V6 (RH-39673)
- Sometimes hangs when adjusting clipping planes (RH-39332)
- DPI Aware: Pixelated text and images in the installer splash (RH-37433)
- Display:
- Array preview is clipped if GPU tessellation is used (RH-39348)
- Block Layer Lock/Unlock Affecting Visibility (RH-39585)
- Blocks are drawn with wrong color (RH-39488)
- Clipped block instance does not follow object display mode (RH-40093)
- Curve thickness draws too thick at increased text size (RH-39977)
- Disable GPU Tessellation for Intel HD 4000 (RH-40027)
- DraftAngleAnalyisis and surface edges (RH-39823)
- Dragging a surface leaves edges preview does not show surface edges (RH-39686)
- Dynamic drawing of curves doesn’t show (RH-39974)
- GPU Tessellation issue 1 (RH-39088)
- GPU Tessellation issue 2 (RH-40034)
- GPU Tessellation on by default (RH-39957)
- Ghosted block & clipping (RH-39775)
- Handle zoomed in cases with GPU tessellation (RH-39251)
- Handle zoomed in cases with GPU tessellation (RH-40035)
- Has no dynamic display (RH-39722)
- Leaves out edges (RH-39793)
- No preview in Array (RH-40047)
- Rendered misses some waves (RH-39958)
- Rendered mode material glossiness factor needs tweaking (RH-39729)
- Selection highlight (RH-40098)
- Shaded mode environment map upside down (RH-40087)
- Display: OpenGL 3.3: SSAO glitch when normals don’t correspond to actual surface geometry (RH-38852)
- Docking Tabs:
- EditPythonScript: RhinoCommon help in Python editor output window formatted incorrectly (RH-39961)
- Eto: Pasting text with non-breaking spaces into RichTextArea adds a normal space after the non-breaking space (RH-39341)
- Explode: Add ‘Apply to all’ warning (RH-39968)
- Export: SVG export clips parallel lines to printable area if extents option is used (RH-40142)
- ExtendSrf: Creates extra geometry (RH-39832)
- ExtrudeCrvAlongCrv: SubCrv and ExtrudeCrvAlongCrv (RH-39694)
- File IO:
- Add name (when there is one) to geometry node in dae export (RH-39663)
- Add support for Opening/importing PDF files for parity with Windows V6 (RH-39646)
- Fails- example file (RH-39672)
- STEP cones don’t import correctly (RH-39884)
- STEP import color-by-face problem (RH-39684)
- STEP import fails to trim surface in V6. V5 ok (RH-40032)
- STEP round trip messes up an edge (RH-39664)
- Saving as V5 improperly sets current layer (RH-39266)
- Simple hatches do not import with DWG files (RH-40244)
- FilletEdge:
- Grasshopper: Split brep in GH can not separate multiple parts (RH-38920)
- Gumball: Snappy gumball 2D scale not working (RH-39828)
- IPlane: Creates object as pre-selected (RH-39510)
- Make2D:
- Mesh:
- MoveUVNOn: MoveUVN Dissapearance (RH-39861)
- NamedView: Drag&Drop doesn’t work with Named Views and CPlanes anymore (RH-39461)
- Options: Z-axis display control ineffective in Options, OK in Display panel (RH-38602)
- Point: Canceling Points command leaves markers in viewports (RH-39719)
- PointCloud:
- PointDeviation:
- Properties:
- PropertiesPage: Icons for buttons are fuzzy (RH-38872)
- RDK:
- ReduceMesh: ESC key doesn’t remove locked point display (RH-39602)
- Rendering:
- Rendering: Materials:
- Rendering: Texture Mapping:
- SDK:
- SDK: Python:
- SDK: RhinoCommon:
- Selection:
- SetDocumentUserText: An extra frame around the Document User Text panel (RH-39966)
- SetUserText:
- SubDFromMesh: Display error with SubDFromMesh command (RH-38346)
- TextObject:
- Toolbar:
- UI Cleanup: Generate undo record for User Text panels (RH-39669)
- Undo: Error (RH-39430)
- ViewCaptureToFile:
- Gumball:
- SDK: RhinoCommon: DisplayPipeline.DrawPolygon() Only draws convex polygon. (RH-39256)
- SelBrushPoints: Cannot “Unbrush” control points and vertices (RH-39720)
- BoxEdit: Pivot blocks on insertion point option (RH-31913)
Download Now and report any problems in this forum.
