New Family Node Removes Family List from Project Browser and creates empty family
Hi all,
I was wondering if anyone else was having this issue. When I instantiate a Family with the “Family.New” Node, it removes the list of families in the Project Browser. I then have to restart Revit to be able to see the Family that was made.
The Family.New node also doesn’t seem to be making any geometry anymore on my end. It is essentially creating an empty family. I looked into the zero length edge problem discussed in another thread on here, and then even tried with a simple box brep with no luck. This happened after I updated to the latest version where I am now getting the “dll cycles” error .
I have uninstalled and reinstalled RiR. Updated to the latest Rhino WIP as well. Any help is appreciated, thanks in advace!
Which version of Revit are you using?
In case you installed a service release please specify the minor version too.
Thanks,
Hi Kike,
I am using Revit 2019.2
Rhino 7.0.20021.12255
RiR 0.0.7330.31081
The fix is available.
You will need to update Rhino WIP and Rhino.Inside Revit.
Thanks Kike, I tested it this morning and I have full functionality again. Appreciate the help!
@kike just published a fix for this
