I have a script to create revit families that was working fine/ I’ve updated to Revit 20234 and a the latest daily build and now it seems that component family form will no longer accept the visibility integer identifier and the revit categories. See images attached. The object going in to the components appear to convert to null objects
I tried putting the output from the new subcategories list but that doesn’t work either.
or from the native construct visibility component.
Works fine when nothing is connected to it.
Component worked fine before. It seems recent changes have lead to some unanticipated sideeffects and broken then component.
Hi Benjamin, a quick test here is OK.
Rhino.Inside Revit: 1.19.8753.16429 (2023-12-19T09:07:38)
Rhino: 7.37.24004.15001 (Rhino 7)
Revit: 2024.0 (24.0.4.427)
I noticed the same behavior in 1.20.8728 build.
Don´t know how it is related, but newly-placed RiR node looks different from the old one on the input side …
I just placed a new node on my canvas. Once re-connected to proper input ports, the issue is gone, the old node gives an error, the new one not.
Regards,
Pavel
