I’m just getting started with Rhino.Inside. I’m somewhat familiar with Grasshopper, Rhino and Revit but my 2024 version of Revit now seems to be crashing every time I try to create a simple generic family from a few breps in Rhino. Attached is the grasshopper file I am trying to use for this workflow. Can anyone tell me what I’m doing wrong? It appears there is something wrong with my naming convention (see attached screenshot).
Another - more minor - issue: Earlier, when I was able to get this Grasshopper routine to successfully generate a Revit family (so exciting!), I was confused as to why it did not name the new file by the name I inputted into the new family node (the “N” input). Any help with these issues would be greatly appreciated.
Grasshopper says a “Family 7” has been created (see attachment) but the Revit file I am working on has no such family listed under generic families. Clearly I’m missing something obvious. It appears Grasshopper is perhaps generating a family in another Revit file but I only have one Revit file open. Totally stumped on something I’m sure is obvious to someone who is more familiar with the interface. Any help is appreciated. Also, I am suspecting it is possible for a Revit file to lose its connection with a Grasshopper file. Any help confirming the association of a Revit file with a Grasshopper file would be greatly appreciated.
Thanks, Adam. I wound up just entering the text by right-clicking the name input and making a single variable entry. You were probably right about the spacing. Am I correct in thinking you can usually use a panel to supply a string a name variable to a node?
