signetTrial.3dm (3.2 MB)
Hi! i’m trying to make a signet ring and am trying to use networksrf command to complete it. it says “unable to sort curves” if anyone could help that would be much appreciated, thank you!
Turn off autosort and select the curves in the correct order.
http://docs.mcneel.com/rhino/5/help/en-us/commands/networksrf.htm
Thank you for the reply Michael Pryor! Im sorry im quite new to rhino, these are pictures are the first and second directions and it still says its unable to create the surface. Thank you again
That’s not a network, you should use sweep 2 for that.
here works fine with NetworkSrf, just select the curves in order, first the open curves, then the closed ones
The sweep 2 worked fine, thank you Michael Pryor. but unfortunately even when selecting the curves in the right order it still cant do it! but thank you very much!
