I use rhino almost daily for work. Today i was welcomed by a barrage of errors on launch
bellow are some screenshots
help
Hi Adel,
Please run SystemInfo and post the result.
If this is windows please try opening Rhino in Safe Mode and disabling 3rd party plugins. (search windows start for Rhino in Safe Mode)
Rhino 8 SR23 2025-9-8 (Rhino 8, 8.23.25251.13001, Git hash:master @ e75a9d62e23cc6f52d4ef68eb7eda9f8da9b6cd9)
License type: Educational, build 2025-09-08
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 24GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in
Primary display and OpenGL: NVIDIA GeForce GTX 1080 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 9-5-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.29
Integrated accelerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-5-2025
Driver Version: 32.0.15.8129
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\Adl\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PlanFinder\1.3.1\PlanFinderRhino8.rhp “PlanFinderRhino8” 1.0.0.0
Any particular reason you are running in .Net 7?
Lets do a repair install of Rhino 8. Go to Add or Remove Programs and Select Rhino 8, modify the install and repair.
no difference after repair
can’t change the the .Net runtime from inside rhino as the command is not found (SetDotNetRuntime)
We should also remove this 3rd party addon for troubleshooting purposes.
@Japhy repaired the runtimes and removed all 3rd party plugins. no change
Please run systeminfo again.
Are there any Windows updates available? They have a hotfix coming out due to issues on the last one.
yes, but i had to roll back due to issues. this might be related
.NET Framework 4.8.9221.0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.24.25281.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.24.25281.15001
@Japhy I updated rhino to s.r.24 and it seems to have fixed the problem.
@japhy i think what happened was that i had recently updated to s.r.24 but due to problems with the windows update, i had to do a system restore to about a week ago, when i was on s.r.23. i guess some files remained from s.r.24 causing conflicts
