Hi Team,
Issue
One of our team members is seeing the following plugin error in Rhino8 and we would like to understand why this might be happening.
About the plugin
Out plugin is targeting .Net Framework 4.8 and Rhino 8 runs under .Net Core 7.20. So we are not entirely surprised by seeing this error. But here’s what surprise us the most. out of three machines we tested this on, this error is happening on only one of the machines.
Side Note:We should should also share that we have other plugin that is also targeting .Net Framework 4.8 and it works fine in Rhino 8 running under .Net Core 7.20.
System Info
The system information for the three machines we tried this on.
System-1: No plugin error
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Commercial, build 2024-10-08
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display and OpenGL: NVIDIA RTX A4000 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.76
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: NVIDIA RTX A4000 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.76
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-23-2024
Driver Version: 32.0.15.6076
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\WB_RHTrack (f1b547e5-c3af-478d-84ee-6804536a8bb2)\1.0.7346.25956\WB_RHTrack.rhp "WB_RHTrack" 1.0.7346.25956
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp "V-Ray for Rhino"
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp "Datasmith Exporter" 5.4.3.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll "Enscape.Rhino8.Plugin" 0.0.24138.1238
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\ElefrontProperties (5db9285b-b408-41e2-b815-ed6ad84fd4a9)\1.0.0.0\ElefrontProperties.rhp "ElefrontProperties" 1.0.0.0
C:\Users\nycdvc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\WombatRhino\1.0.5.17\WombatRhino.rhp "WombatRhino" 1.0.5.17
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.230\Ladybug.RH.Loader.rhp "Ladybug.RH.Loader" 1.38.230.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.52.19\Pollination.RH.Loader.rhp "Pollination.RH.Loader" 1.52.19.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Users\nycdvc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp "PanelingTools"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
System-2: No plugin error
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
- Secondary monitor is laptop's integrated screen or built-in port
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-3-2023 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 6-25-2024
Driver Version: 32.0.15.5612
Total Video Memory: 6 GB
C:\ProgramData\Proving Ground\Conveyor\ProvingGround.ConveyorRhinoInside\net48\ProvingGround.ConveyorRhinoInside.rhp "Conveyor Rhino NET8" 5.1.0.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll "Enscape.Rhino8.Plugin" 4.1.1.35
C:\Program Files\Orkestra\Orkestra\net7\OrkestraRGH.dll "Orkestra Online" 2024.1.9.1
C:\Users\melrzm\Downloads\net48_andrea\net48\Wb.ModelEstablishment.Rhino.rhp "Wb.ModelEstablishment.Rhino" 1.1.3.0
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Users\melrzm\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp "PanelingTools"
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp "IdleProcessor"
System-3: Plugin error
.NET 7.0.20
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 10-6-2023 (M-D-Y).
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 12GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Total Video Memory: 12 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\ElefrontProperties (5db9285b-b408-41e2-b815-ed6ad84fd4a9)\1.0.0.0\ElefrontProperties.rhp "ElefrontProperties" 1.0.0.0
C:\Users\sydata\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\WombatRhino\1.0.5.17\WombatRhino.rhp "WombatRhino" 1.0.5.17
C:\Users\sydata\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp "PanelingTools"
We’d be happy to shared the build of our plugin privately if that helps.
