I am trying to figure out how to create a mound for the site model that I am trying to figure out.
I was wondering if anyone knows how to maintain the edge condition to be flat and not lift up.
No matter what method I try including: patch, rebuild, points on - it seems like there is just no way but
the edge being lifted up as I am trying to achieve the mound to sit flat.
Thank you for your suggestion! When you say including the some points in input, do you manually include points before you patch?
The patch command I ran to get the shape is a simple arc that goes across the profile shape and the profile that I got from the command dup border. I selected the two curves and ran patch, would I need to input ‘points’ before running the command and select them?
