Need help with fillet
Hi rhino experts! Any help would be much appreciated, im rushing to print this out for molding, so i hope to find any solution/method to achieve my desired outcome
I cant seem to be able to make a fillet with a radius of around 2 to 3mm at this area as shown:
i’m not sure if i made a mistake when doing the desired shape.
what i did was create a subd version of the shape that i want to deboss into the middle of the shape but the issue comes when trying to fillet it to make it smooth.
My file:
Model.3dm (285.4 KB)
The model in the file does not seem to correspond to the picture that you posted.
The file is before differencing…
This is after
Model.3dm (1.6 MB)
Ah, got it. I see the problem that occurs with fillet edge. Instead of using FilletEdge, you can use the Pipe with BlendSrf technique explained in this video https://www.youtube.com/watch?v=4mXv4IaWSBw
Attached is the result for a pipe of 1 mm radius.
Model-pipe+blend.3dm (1.8 MB)
I created a ticket for the fillet problem https://mcneel.myjetbrains.com/youtrack/issue/RH-83619
i can’t access the file because i only have rhino 7… could you maybe save as rhino 7 if possible?
This is v7 - I encourage you to try the pipe+blendsrf yourself though :slight_smile:
Model-pipe+blend-v7.3dm (1.8 MB)
well… i just learned a new thing it seems haha. i actually never thought blend can be used in such a manner to join 2 edges with a nice smooth surface. Thanks so much for the quick response, as well as introducing pipe+blendsrf skill/trick to me!
