Need advice command one direction curve project
Hi
I learn this tutorial Paneling Polysurfaces Using Grid Projection
Paneling Polysurfaces Using Grid Projection - YouTube
I try a lot of time but can not create grid in both side. It should be a group.
Details as screencast
Need advice to create grid in both side
Thank
Travis
Are there anyone confront same issue? or only me
Thank
Travis
You should move the base line to the bottom the polysurface, then try the command PtGridCuve again.
PtGridCurve
Hi @jessesn
Thank your suggestion. now I see we only can create grid each side at time.
Travis
