Each time I import 3D solids dxf into Rhino it is creating naked edges error. It is creating an additional point and a line that is distorting the edges. How do I avoid this from happening? Any guidance would be a big help.
Hello - it looks like these are simply not very tightly constructed - can you send an example input file?
@pjoshi - how are you getting this file into Rhino? Just opening the file you sent to tech is fine - no naked edges - in both V5 and V6, Are you opening or importing? If you are importing, what are the units and tolerances of the file you are importing to?
