Hi Charles - in this particular case the quickest is to remove that flat side adjacent to the naked edge and Cap the object to close it off. I don’t know if this is a more general problem though and needs a different workaround.
Well, after more testing, it looks like it is the reading part - that is, a V6 export, imported to a cm, .01 file in V5 has the same naked edge as from the V5 export, but v6 imports it’s own export in a .01 cm file, as well as the V5 export, just fine.
I don’t understand the problem. Why are you exporting to dwg then bringing the model back into Rhino? When I open your dwg file in AutoCAD and run an stl check, it says the model is watertight. What are you using the dwg file for?
