Naked Edges
Hi, I have 2 naked edges to get rid of before I can print. I’ve tried sweep2, joinedge and deleting with ctrl+shift none of these have worked the edges seem to be unattached and only they can be selecting when I try to join. Is there anything else I can try?
13232 - - Murphy_B_Tech3 (2).3dm (3.9 MB)
Try using RemoveAllNakedMicroEdges.
dear Brianna
check those sufaces.
also the ground surface is not completely on the same z-level.
somehow you have to fix those imprecisions first.
also the area below the columns has 0 thickness.
for some (precise cases)
_mergeAllCoplanarFaces
might help.
(and cases where it should help, but did not merge faces, it shows some errors)
joinedge is more cosmetics than modelling - it will skip the document tolerance - and therefor in most cases creates dangerous details.
do you have any earlier state (eg. curves, simpler volumes…) - so it will be easier to repair the defects…
Thank you! This helped a lot.
