Naked Edges
Hi, I can’t seem to get these naked edges to merge. Look at the extruded model on the left in my file. Any help would be appreciated. Thanks and Happy New Year! SHUGHES PENGUIN.3dm (2.8 MB)
Hello - it looks like you have used JoinEdges on this part. Please ignore that command and only use Join. To fix this, Explode, RebuildEdges and then trim off the bits that are inside the top ring:
Then Join and MergeAllFaces to clean up if needed.
There are some other messy areas though - it may be best to clean up the curves and extrude and fillet the object again - for example, make sure the curve has at least the radius of the fillet (.25) that you want to add around the edges-
SHUGHES PENGUIN_PG.3dm (680.1 KB)
