(FINAL)
The entire image is actual geometry producing actual Bokeh. (Rendered in Bella-Rhino)
Cool ! I didnāt know this, Iāll definitely have a look, Thank for the tip
The feature is hidden (read: not really supported, although it should work).
nice render~
nice render tip~
all of you ^^
This model can be found here
: https://www.cgtrader.com/free-3d-models/architectural/lighting/chandelier-royal-classic-sevilla-dia004-06-wg-maytoni-classic
The frame and candles need to use ātoSubDā to smooth them out first.
I donāt want to hijack Thomasā thread, so if you want to split this out to another thread (not sure if I am able to do it myself) please do.
I am not sure if these Blades & BladesRotation values are available to plugin code (or maybe they are in the v7 sdk), but the question I have is whether there exists a high-level plan for implementing physically-based rendering concepts like these.
Take for example the Focal Blur panel and parameters, these have been difficult to deal with, because on one hand I want to take what Rhino provides and not duplicate it, but on the other, for example the f-stop gets greyed out when we are in āautofocus on selected objectsā mode ā and in that mode, I still want my user to be able to define their f-stop, so they can get the focus point from the selection , but still play with DOF. So I end up with a bit of a twilight zone implementation where sometimes you use the f-stop in Rhinoās panel, while other times, you have to switch over to the Bella camera parameters to control it.
For aperture blades control, these params are not (afaik) exposed, so I provide them, but at some point I imagine they will be, and I will have to choose how to deal with it ā ignore Rhinoās, or get rid of mine, and have data loss when opening a file that was created prior.
So I guess Iām saying, the camera/view/viewport area in general feels haphazardly put together, and I wonder if there are any plans to refactor things to a more cohesive model once these various hidden parameters graduate to being officially included.
Agreed. As users we would benefit from developer collaboration towards UI consistency and the physical camera model is the way to go.
There are no clearly defined plans other than āimprove everything render relatedā.
Iāll log YT items to record the issues you have mentioned and ensure @andy knows of your requests and needs (:
Thanks, Sir.
Right now pluginās have their own fStop input box on top of Rhinoās. Can the two be synchronized ? Is it possible when we enter a value in Rhino fStop field to also auto-update the fStop value of the plugin; in another tab ? ⦠and vice versa. Right now we end up with two separate fStops reported in two locations.
That may be possible, but it would be up to the plugin to do it (so Iāll look into it).
Is it intended that the āautofocus on selected objectsā mode has been removed in sr8?
This is on win10, 7.8.21196.5001, 2021-07-15.
I believe it is intentional. @andy, am I correct?
Well for what itās worth, when that was enabled Iād keep track of object selection and then use it to set focus distance as the view changed:
Rhino would disable the f-stop spinner in this mode, but my user could use the f-stop in my camera panel to set the DOF.
It would probably have been more useful to have the mode accept a persistent object selection instead of always switching whenever you selected something else, but it was still a useful mode, since the manual focus mode has to be re-focused whenever you move the camera.
So I guess the most likely outcome from this is that Iāll just stop supporting the Focal Blur panel, and offer my own versions of these modes.
IMHO anything we can do to work with JD will fall well within the plan to āimprove everything render relatedā
would you do a quick explanation of this and an example of how best to use the effect?
specifically how bokeh and DOF are different ( or can work together)
(If it matters) The way I work as a user is choose the exact angle and an fStop for which portion of the object I prefer focused and then pin them down with a NamedView save. If the object is deep Rhino canāt know which portion of it I want in focus.
To accomplish precise focus, I use one of my own old scripts (CameraLine) to extract a line between camera and target and measure the exact distance to the part of the object I want focused and dial it in manually ⦠or directly manipulate Rhinoās camera target point (show camera) and would rather have that slide on the line I extracted. It would be more helpful if Rhino provided me with a way to do the sliding.
