Dear all,
I would like to dig multiple circular holes in a closed brep, but it ends up with open brep when I want a closed one (filled, to be 3d printed for example).
If you create 7k cylinders and then do a solid difference, indeed it is going to take time.
Better is to have a single solid as “cutter” and then do a solid operation between just 2 solids.
In this case, I’ve created another positive solid, so your target is achieved with solid intersection operation.
Note: most of grasshopper components can display something. Surfaces and Breps needs to be “meshed” to be displayed, same thing that happens in rhino:
If you create 7k cylinders, and leave the component with display ON, you are going to wait more because of the meshing part.
Disable all the components preview where you don’t need it.
Or, globally disable grasshopper meshing by setting it to wireframe mode
