I have 2 surfaces with some holes in each of them and I would like to create a closed brep. So I am trying to find a similar way to rhino BlendSrf command for example in order to bridge the edges of the 2 surfaces I have. It would be greatly appreciated if you could help me with this.
different how? Can you just upload the surfaces? Are they just different sizes? different numbers of holes per surface, different number of sides per hole? ect. Upload just the rhino of the two surfaces.
EDIT: Just opened your surface. Yea that isn’t gonna work, you have holes in the top surface that have nothing to match to.
Yeah I know…I didn’t know how to avoid this…so if this is the reason loft doesn’t work I will try to find a way to retain the same number of holes on each surface…anyway thank you very much for your help!!
