I’m running a rig with multiple, different graphic cards. I have a Quadro k5200 (primary) and a GeForce 1080ti (for additional CUDA cores for rendering in Octane). I noticed that my Rhino displays were acting sluggish with some larger models so I investigated and it appears that Rhino was using the 1080ti over the Quadro. I disabled the 1080ti and the performance issues corrected themselves.
Other than control the card via device manager, so are there any ways to show Rhino what GPU to use as a primary graphics card?
Hi, yes the quadro should outperform the 1080 in Rhino5 due to it’s improved AntiAliasing. Quadro is extremely much faster on this in the older OpenGL version that V5 uses.
You can go into your nVidia drivers and set what graphiccard to be used for Rhino5. It should already have a profile for Rhino5 and if not then just make one.
Good luck and I am happy to hear that Holomark helps you out. It lists both cards right?
