Hello, do you know how can I achieve something like this:
I mean: chamfer over chamfer to create faceted round-like edges. But automatically. A macro maybe?
Hi @Bruno_E1 - You can run the ChamferEdge command as many times as you want and chamfer the previously chamfered edge. You can use the Repeat command, followed by ChamferEdge. This will run the ChamferEdge command in a loop so you donât need to execute it over and over again.
thanks I will try with Repeat
âRepeatâ, followed by âChamferEdgeâ, will not create equally spaced chamfers when executing them multiple time. IS there a way to have equal sides of the multi-chamfers? 3DS Max have this functionality for poly models.
I agree. I was also hoping to find a more automated solution. Ideally, something that doesnât require to select more than the initial edges and define a number of sides to create. I find myself in the need to use it very often.
Currently, you can workaround that limitation by following these steps:
You can automate these 3 steps with the following macro:
! _ExtractSrf _Pause _Rebuild _Pause _DivideAlongCreases
The tooltip that I added to this is âMulti chamfer after Fillet edgeâ
since it has been Christmas recently, here is a pythonscript doing this. Hope it works. Be aware to set to select the edge right in the middle. No warranty, take it as a starting point. Whatâs the reason to do so many chamfers, and why not using a radius instead?
import Rhino
import Rhino.Geometry as rg
import scriptcontext
from threading import Thread
from time import sleep
REPEAT = 3
WAIT = 1 #secs
#Selection
edgeSelection = rs.GetEdgeCurves("Select Brep edges",1,1)[0]
CURVE_ID = edgeSelection[0]
PARENT_ID = edgeSelection[1]
SELECTIONPOINT = edgeSelection[2]
BREP = None
def findTwoClosestEdges(searchpoint):
global BREP,PARENT_ID
##rs.AddPoint(searchpoint)
#searching adjacent edges
minDis = float.MaxValue
secondMinDis = float.MaxValue
index = [-1,-1]
##mes = "\n\n"
for edgeNode in BREP.Edges:
edge = edgeNode.EdgeCurve
t = edge.ClosestPoint(searchpoint)[1]
cp = edge.PointAt(t)
dis = cp.DistanceTo(searchpoint)
##scriptcontext.doc.Objects.AddPoint(cp)
##mes +=" %f \n" %(dis)
if dis < minDis:
secondMinDis = minDis
minDis = dis
index[1] = index[0]
index[0] = edgeNode
elif dis < secondMinDis:
secondMinDis = dis
index[1] = edgeNode
##mes += "\n\n"
##print mes
##print "%f %f" % (minDis,secondMinDis)
# Unselect
rs.UnselectAllObjects()
# reselect relative
robj = Rhino.RhinoDoc.ActiveDoc.Objects.Find(PARENT_ID)
robj.SelectSubObject(index[0].ComponentIndex(),True,True)
robj.SelectSubObject(index[1].ComponentIndex(),True,True)
#redraw
scriptcontext.doc.Views.Redraw()
# return selected edges
ptA = index[0].EdgeCurve.PointAt(index[0].EdgeCurve.Domain.Mid)
ptB = index[1].EdgeCurve.PointAt(index[1].EdgeCurve.Domain.Mid)
return (ptA,ptB)
SEARCHPOINTS = None
def asyncSelection(edge):
global SEARCHPOINTS
sleep(WAIT)
SEARCHPOINTS = findTwoClosestEdges(edge)
sleep(0.3)
def recursiveChamfer(level,searchpoint):
global SEARCHPOINTS, BREP,PARENT_ID, CURVE_ID
BREP = rs.coercebrep(PARENT_ID)
level+=1
if level >= REPEAT:
return
elif level == 0: # initial chamfer
rs.SelectObject(CURVE_ID)
Rhino.RhinoApp.RunScript("_ChamferEdge _Enter _Enter",True)
else:
thread = Thread(target = asyncSelection, args = (searchpoint,))
thread.start()
thread.join()
if SEARCHPOINTS != None:
searchpointA = SEARCHPOINTS[0]
searchpointB = SEARCHPOINTS[1]
recursiveChamfer(level,searchpointA)
recursiveChamfer(level,searchpointB)
recursiveChamfer(-1,SELECTIONPOINT)
This is what happened at level 3 recursion with one selected edge:
thank you very much for the script work. Iâm trying it. Unfortunately, Iâm having trouble. I always get: " no attribute âEdgeCurveâ ". I guess I may be doing something wrongâŚ
In this context, I avoid using any curved surfaces because everything will be converted to meshes and imported in UE4.
I use chamfer and then âweld mesh edgesâ on cornerâs edges. So that my mesh results in fewer polygons, more quads, fewer triangles and itâs easier to unwrap.
mhh, Iâll test it on R5 as soon as I find time for it. Its made in R6.
