(beginner here) So, I would like to create a boundary around a site with vertical ribs (reference photo). However, I’m not sure how to go about creating a seamless model that goes around the site (as indicated by the surfaces drawn). It is created by separate surface at each corner.
I have done each wall separately, but the corners are not great especially if I want to fabricate it. Ideally, I’d like fillet corners, however that creates another surface that I’d have to separately consider.
How can I consolidate this into one open structure that has fillet corners and is also not closed?
If I assign multiple surfaces to the Surface Param, when I try to project the curve for the rib, I only get a singular output and not all walls/sections are considered. So far, I’ve tried grouping the walls in X direction and Y-direction and doesn’t work.
I hope I am making sense…
*EDIT: I’ve updated my structure to go all the way around the site now, but the same problem remains.
Thanks in advance!
2. Structure.3dm (19.3 MB) 2. Structure.gh (25.7 KB)
