Hello all !
I try to create one surface through 3 closed curves but none of the Grasshopper components for creating surfaces from curves work.
Here is a grasshopper canvas to explain.
Thank you for your help !
This is a “painted myself into a corner” problem that could easily be solved if the base surface (spherical?) were available - except the tiny piece is apparently on a different surface?
I’m not going to touch this again but for anyone who wants to try, there are three curves on two or three different spherical surfaces and @johnluc_fr is looking for a smooth transition between them.
Hello
This is a difficult subject. There are tons of discussion about surface with nice curvature. Some are masters to make some nice transitions. XNurbs seems a good tool for that. Look at discussion on the tool, on class A surface, G1, G2 … I think the difficulty is also the difference of scale. I tried to make it with some others curves (blend crv) and Network surface but without success.
Thank you for the information. It also seemed to me that the problem was not that easy to solve.
I tried installing the Rhino XNurbs plugin but it fails to load. When loading, Rhino 5.0 quits on its own.
Happy Holidays !
JLuc
