in the tutorials when we want to select a “Face” in SubD and then “Move” (Not Extrude!) the Face towards somewhere, the instructor simply uses gumball and drags the selected face, then Obviously only the selected face moves!
but every time I want to do a similar job, the whole Object moves, Not the Selected Face that I chose! I use ctrl+shift to select the face and then use gumball but it is not working!
am I missing something? it is also happening with control points.
thanks.
I guess it’s a bug because when I copy and paste the object in a new rhino 7 file, the issue solved. here is the video of it. thanks.
Hi @alirahi32
This behaviour makes me think you may have SoftTransform enabled maybe…
If this is the case, depending on the falloff radius set, a similar behaviour may occur.
Hope it helps.
Regards
Rodolfo Santos
Yes, I checked and when I disabled the softTransform it works correctly!
A visual feedback somewhere showing the status of that command would probably help.
Regards
Rodolfo Santos
Hi -
We have that on the list as item RH-55559 (not public) - I’ve added this thread for additional background.
Thanks,
