is it impossible to use the classic GH move component on a Revit element or am i doing something wrong?
Thanks
The move would be done on the Point > Location, no?
https://www.rhino3d.com/inside/revit/beta/guides/revit-interact
So youāve got no choice : the location point used when you create the component has to be in the good position immediatly because it canāt be adjusted afterwards?
What if i need the geometry of the component to calculate its good position?
No. The GH transform component move the geometry-extracted-from-revit-element and not the actual Revit element. We need to create a āSet Locationā component for Rhino.Inside.Revit
Added an issue for this:
Hi
I can see that it is an old post. Has the āSet Locationā been done?
What I need is to change an existing Structural Framing in Revit to a new location using a reference line.
So, the input being the element that need to change (structural framing), and a geometry input (new line). It should then relocate the existing revit element based on itās location line.
This could also be point input for families that are set by point.
/Bjarke
The release is ready!!
Hi
Iāve been using the Set/get Element Location component extensively since the release, so first of all thanks for that
But I realized today that it doesnāt support Structural Foundations if I need to SET the location. Iām getting this error message:
- RevitAPI: The input familyInstance is not of a structural framing category.
Parameter name: familyInstance
I am able to GET the information from the same elements.
Am I doing something wrong here or is it under development?
Thanks
/Bjarke
Hello, I am coming to this after quite a while. Iām curious if anyone has had success with this tool. I would like to move Revit elements based on updated element locations from a Rhino model. Is this a functioning tool?
