Hello guys, I am new to Rhino.inside and wondering if there is a way to move, rotate, and align after “Add Component (location)” After the standard move, I am getting Null results in the panel. Thank you.
Thank you Japhy!
Hi, Japhy
Is this the correct way of changing the location of the objects?, and What " Element Location" should be connected to in order to change the facing of the objects? Thank you
