How you move will depend on your Revit Element. A simple family can be moved by providing a new point location into the Element Location component. This wonβt take into account for rotation, that would require a plane (as well the Family being Work Plane Based)
Thank you for giving me a solution in moving Revit elements. I think this a great way to Revit components using grasshopper and showing how to move revit hosted components.
I do have one more question, would it be possible not to move my Revit components at all, I was planning to use the Revit components as my base file and then add grasshopper created elements into it; to which Grasshopper elements should moved and not the Revit elements.
That being said, going back to the picture I previously posted, I was hoping if the grasshopper louver I made can be aligned with the 2 red lines, without the revit model being touched.
I would be glad if you could help me with this one.
Exactly how you will determine the points/ planes to move from is geometry and workflow dependent. Is the Louver a block? Are you going to a end of the line or just changing XY. If you get stuck please post a file, thanks.
