Move an existing revit level by offset
Hi Guys,
I have an existing revit level and I want to move by a distance and I used the
z vector and move component and under the panel the distance works but
didn’t apply to revit?
Any help?
thanks
Hey @sketzjewel ,
So usually if you want to make changes to Revit elements, you would need to use one of the available RiR components make the change inside Revit.
A way to do that for a level is just like you would in the UI using the properties menu and adjusting a level’s elevation parameter value… the same way you can do it through GH.
Hi Mohamed,
Thanks Mohamed, Beautiful!
cheers
