Moving a Curtain Wall's Level
I have to move a lot of Curtain Walls (and Walls) in a project. It’d be great to do so at one go, as all of them are moving up a level. Looking at RiR components, I don’t see a means to move the Level Constraints of these walls in one fell swoop. Do we need to change the base points or something else? Thanks.
Hi Clarence,
You set the Base Constraint Parameter like so…
Thanks! Looks like I’m going to use some Relative Items to grab the right levels and input an individualized branch for each wall instead of the Level Picker.
Is it possible to input a Level as a string?
You can Query Levels via Text input, the Parameter is expecting a Level Element.
You’re the best!
