Thanks.
What element are you changing? Is it a workplane based family? or something with an offset to a level?
Yeah its a Workplane based generic model family.
Maybe i need to build in a offset level parameter to then change that with inspect element.
That should work. I’ll need more information to verify. What is your RiR version and Revit version?
Thanks Japhy. I think i need to just update the family type and not use face placement.
As the elevation is locked from level.
