I’m seeing a strange problem with my RMB when rotating the view. Because as soon as I press RMB I get the last used command popping up, which is obviously interfering with the view rotation. And this last used command prompt will repeat itself over and over again as long as I’m trying to rotate my view. It started a few days ago. I think after the latest Rhino 7 update. It’s hard to say for certain as I haven’t been using rhino for the past few weeks. But it is very unusual because I see it also affecting my V5, V6, V7 and V8. BTW none of any other programs installed on my computer seems to be affected.
I tried switching right and left button functions using the Logitech mouse driver. It works and the problem goes away when rotating with the RMB, except everything else slows down dramatically. I’m not used to opposite buttons set up. My work becomes crawling instead of driving…
I was wondering if there is a way to disable RMB repeat last command function in rhino. I looked up the advanced setting but can’t find anything.
My desktop is very old but still sufficient for my modest needs. Below are the specifics. Thanks.
Rhino 7 SR32 2023-8-9 (Rhino 7, 7.32.23221.10241, Git hash:master @ 3d9c816c4cd57561d12d8f53246bce304f314ba2)
License type: Commercial, build 2023-08-09
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 12Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GT 640 (NVidia) Memory: 2GB, Driver date: 5-11-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 474.44
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-11-2023
Driver Version: 30.0.14.7444
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Users\Darius\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.1\Substance.Win.rhp “SubstanceImporter” 2.0.1.0
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” 7.32.23221.10241
C:\Program Files\Rhino WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.32.23221.10241
C:\Program Files\Rhino WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.32.23221.10241
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.32.23221.10241
C:\Program Files\Rhino WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.32.23221.10241
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.32.23221.10241
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
