The furniture is scaled 1000x when opening up older drawings done in visualARQ. Resetting the scale inside of the elements fixes it though, and it doesn’t explode again. Just wanted to let you know.
@rheinason There was an error in previous VA versions when copying Furniture (or Element) objects using GH styles from one document to another with different units or when chaning the units of the document, that affected the scale of these objects.
This has been fixed in VA 2.3 version, but that file kept the wrong scale on those objects so you may need to change it back to 1 and save the model with the new version.
In any case, you should not experience this error again.
